how much to install electric outlet for electric range
Old 09-22-04, 10:04 AM
chowyunfat2000
Hi,
I need to replace my electric range because it does not work.
However I realized that the range is hard wired and doesnt
have the standard plug.
Can someone give me a ball park estimate of how much
it would cost to installed the standard plug that the new
ranges use?
Thanks,
Arthur
Old 09-22-04, 10:08 AM
R
There are too many variables here. Is a new cable needed? This would be true if the cable is only three wire (and not four wire), or if the cable is the wrong size. What about a new breaker? How far is the range from the panel?
Old 09-22-04, 10:17 AM
Received 1 Upvote on 1 Post
I don't think simply adding a receptacle will require an upgrade of the cable, assuming the electrical requirements of the new range are the same as the old one.
Old 09-22-04, 11:43 AM
Received 513 Upvotes on 418 Posts
Simply adding a receptacle to the exisitng box should not take more than 1hr. Depending on labor rates and travel required I would guess $50-$100.
Old 09-28-04, 12:25 AM
chowyunfat2000
installing a new plug for oven
Hi,
A friend came buy and told me the following:
The wiring for the aluminum is 50 amps and might not be safe
to have a 50 amp oven as it might overheat. He mentioned that I
need a thicker aluminium wire or replace it with a copper wire of the same
length.
Does that make sense?
I would need to buy 25 feet worth of wire, along with the other parts.
Any guess on an estimate for this kind of job?
Thanks,
Arthur
Old 09-28-04, 06:33 PM
Aluminum wire is fine for a range. 50 amp should also be fine for a range. You still need to answer the questions. What guage wire and how many conductors? Can you see the cable? Check the jacket and look for the numbers.
