Breaker box ground wire
Old 09-28-04, 05:29 PM
sth17
I'm in the process of replacing all my galvanized water pipe with new copper piping. What do I do with the main electrical ground that is currently connected to the main incoming cold water pipe?
Old 09-28-04, 05:38 PM
Connect it to the new pipe in the same location which should be withing 5 feet of entering the house.
Old 09-28-04, 06:07 PM
sth17
Copper Pipe
So I can ground it to the copper pipe? I didn't think I could use the copper as a ground.
Old 09-28-04, 06:08 PM
Yes, the copper pipe is one of the ground sources. There should be at least one more. However, you are also bonding the water pipes to the ground in your electrical system at the same time.
Old 09-28-04, 06:16 PM
The copper is a much better conductor than the galvanized. However, where are you connecting the copper to the existing plumbing, and how are you making the connection? Are you putting in new copper all the way out to the street?
Old 09-28-04, 07:40 PM
sth17
I'm changing it as it enters the house. And I'm using a dielectric union between the galvanized and copper. Thanks.
Old 09-28-04, 07:47 PM
You may need to jumper around the union if it doesn't conduct electricity through it.
Old 09-28-04, 08:09 PM
sth17
That's right. Thanks for the tip!
