switched outlet question
Old 10-03-04, 04:08 PM
jam92102
Question switched outlet question
Hi everybody! I have a wall switch that controls both my light and a wall switch. Is there anyway to wire the outlet to stay on all the time but still have the switch control the light?
Thanks for any help you all can give!
Jim
Old 10-03-04, 05:55 PM
R
Try your post again.
Do you mean that ypou have a switch that controls a wall receptacle and a ceiling light?
If that is what you mean then you need to supply some additional information. We need to know exactly how everything is wired. It may or may not be possible to make the receptacle always hot with the existing wiring. It all depends on how the wires are run, and whwat sort of cables are used.
Old 10-03-04, 06:22 PM
jam92102
Ok, yes that is my situation I'll check when I get a chance about the wiring. Thanks!
