Correct earth cable size
Old 10-04-04, 09:42 AM
uprichard
I had a look at the wire size used to connect a sub panel in my house.
The sub panel runs 12 lights and 5 sockets.
The sub panel comes from a 30amp double pole on the main board and uses
3 AWE #10 wires (Live and common), but the earth is AWE #12
Is this OK? or should I get the #12 changed for AWE #10
Thanks
Old 10-04-04, 10:59 AM
HandyRon's Avatar
If this is under the jurisdiction of the National Electric Code, then a 30A feeder requires a #10 AWG copper equipment ground conductor.
