hall light
Old 10-08-04, 07:55 AM
luda
hall light
hi, hallway light with 2 control switches .one on 1 st fl, the other on 2 nd fl. can i jump off the 2nd fl switch and install a wall outlet using the copper wire as the white wire?
Old 10-08-04, 08:00 AM
R
No. No way. never.
Old 10-08-04, 08:05 AM
Received 1 Upvote on 1 Post
You definitely cannot do what you propose, but there might be another way. Depends on how it is wired. The chances aren't great, but they aren't zero either. If you care to explore it, you'll need to shut off the breaker, pull that switch out of the box without disconnecting any wires, and tell us everything you see (all the cables, all the wires, all the connections).
