Craftsman electric garage door opener problem.
Old 10-21-04, 11:24 AM
cthoms
The opener is easily 10 years old. We apparently had a very slight power failure the other day. Very slight. Most digital clocks/appliances in our house didnít reset but some did. And our answering machine reset. Anyhow, ever since then, our three garage door remotes donít work. The hard-wired control works fine but not the remotes. Any idea whatís up?
Thanks in advance,
Chris
Old 10-21-04, 11:37 AM
I would try resetting the code for the unit. Directions should be in your owner's manual or available through Sears web site.
Old 10-21-04, 12:11 PM
You may have had a surge, and fried the receiver.
Old 10-21-04, 01:36 PM
The directions for reprogramming the opener for your remotes are on a sticker on the motor housing. You'll need a step ladder.
Old 10-22-04, 04:14 AM
cthoms
They're fixed! Thanks!
They just need reprogrammed. Should have figured this out for myself. Thanks for the help.
