Which GFI
Old 10-22-04, 10:02 AM
toyotaman11769's Avatar
Which GFI
Hi,
Have a house built around 1965 in which there is on 15 amp circuit for the both baths (lights and outlets) master bedroom and kitchen ceiling light.
I would like to add one 20 amp circuit (12ga) for both bath outlets only.
A single GFI in each, my question is do I use a 15 amp or 20 amp GFI?
Thanks
Old 10-22-04, 10:25 AM
R
Don't waste your money on 20 amp GFCI receptacles. Use a 15 amp GFCI receptacles.
Reason: Do you own anything you want to use in the bathroom that has a 20 amp plug on it? Do you know of anything you want to use in the bathroom that has a 20 amp plug on it?
Old 10-22-04, 11:40 AM
Thanks for the reply
After I bought the 20's I had second thoughts about being able to use the 15's.
Old 10-22-04, 11:54 AM
Received 1 Upvote on 1 Post
If you already have the 20s, you can use them.
Old 10-22-04, 02:51 PM
Thanks for the replies,
I already brought the (2) 20's back....for less money I got (3) 15's.
Thanks again.
