Up grade main panel
Old 10-22-04, 12:51 PM
B
Up grade main panel
Recently purchased an older house I would like to add some circuits the present box is full . Present box is of type that has a breaker on each buss. I would rather go to a larger box than to a sub panel. The new box must be relocated is there a way to splice the wires and stay code legal.
Thank you, Bob
Old 10-22-04, 05:12 PM
ampz's Avatar
What size is the existing service {100A.,150A.,or 200A}? If its less than 200A. then I would upgrade the entire service to 200A. When you ask about splicing wires I assume you are refering to the branch circuit wiring.If so, all that needs to be done is to install a junction box{es} large enough to accomadate the number of wires. Splices will be made in the box & new NM cable {in some cases a few conduit runs can be made here & wires pulled thru} run to the panel. If you do need a new service this is best left to a pro.
Old 10-22-04, 06:38 PM
Received 1 Upvote on 1 Post
Although you can relocate the box, most likely the inspector will not allow you to move the main breaker any farther from where the service enters the building.
Doesn't every type of panel have a breaker on each bus?
