ceiling fan hum
Old 10-27-04, 11:24 AM
travinta
Question ceiling fan hum
I have two Hampton Bay ceiling fans from the Home Depot that I installed separately in the same location. A noticeably loud "electrical hum" emanated from the first, and didn't resolve for a couple of months. I took it down & tried the second one. Same thing. Not quite as loud, but still there.
No dimmer switch. Separate switches for fan & light control.
I'm wondering if this is an outlet problem, or just two junk fans.
Part 2: Home Depot guy told me I should try sacrificing an old extension cord & connect it to the hot & neutral wires in the fan. Not sure which wire in an extension cord is hot & which is neutral, though. Polarized plug is neutral, I assume? Don't worry, I won't try anything without hearing back from somebody.
Thanks.
Old 10-27-04, 11:35 AM
Received 1 Upvote on 1 Post
I doubt this has anything to do with the circuit. Try a Hunter fan next time.
Old 10-27-04, 12:35 PM
travinta
And about the hot/neutral wires in the extension cord? (Just so I can try something before heading back to the store.)
Thanks
Old 10-27-04, 12:58 PM
R
Whcih wire is which in an extension cord is not important for your experiment.
Old 10-27-04, 01:20 PM
Received 477 Upvotes on 393 Posts
Black is hot, white is neutral, green is ground.
Old 10-27-04, 02:30 PM
The neutral is the wire that is connected to the wider of the two blades on the plug. But I think the HD guy is trying to get you killed so you'll quit coming back and bothering him.
Old 10-28-04, 07:17 AM
travinta
I'm still here so far -- thanks for your concern! Fan is still humming from duplex outlet power, so don't think it's a wiring thing. I'm going to take the original advice to go with a Hunter fan & let you know how it goes.
Old 10-30-04, 07:57 PM
green jacket's Avatar
I never like those humming or buzzing sounds either,
I bought a hunter fan, and learned a few things about "hums":
-light kits can vibrate, a glass dome will amplify the natural hum from a motor
-low-profile fans are worse because the motor assembly is direct-mount to the box, whereas a standard fan on a rod isolates the motor, and reduces the noise from resonating throughout the fan unit & ceiling.
For a $125 Hunter fan, it lacks noise suppression, which is a trade-off when the house has low ceilings.
gj
