short?
Old 11-04-04, 10:59 AM
charliet's Avatar
short?
i was scraping loose paint on an interior wall and my metal scraper hit the metal outlet box. i got a good spark and tripped the switch. i reset the switch and everything seems ok, or is it? i live in a 90 year old home that has mostly newer[romex] wiring with some older wiring in spots they couldn't get at.any help would be appreciated, thanks in advance
Old 11-04-04, 11:07 AM
R
Please describe what you mean by "hit the metal outlet box".
Old 11-04-04, 11:37 AM
Received 1 Upvote on 1 Post
There is probably something marginal in the box. When you hit it with the scraper, you probably vibrated it enough for a hot wire to touch the box. I would pull it all out, remake all the connections, and repack the box.
