dryer blowing house fuse
Old 11-05-04, 04:57 PM
snot
my dryer blows the fuse on my wall every time i put it on the normal cycle but it works fine on the other cycles / permenent press ive done the motor the element thermestats new bearings u name it ive done it but ive never found how to fix this problem
Old 11-05-04, 07:38 PM
ampz's Avatar
It may be a short or ground fault at the "normal cycle" position of the switch.If you remove the controlpanel to expose the switch you may see burn marks where it has came in contact with the panel.Hope this helps.
