Recepts to deep....
Old 11-07-04, 07:31 PM
Thunder Valley
Question Recepts to deep....
Hello.
My basement walls (wood basement) are sheeted with T-111, and underneath that is drywall. When the t-111 was installed, they never compensated for the additional thickness and now I cannot put switch plates on the switches or recepticals. Is there an easy way to remedy this without pulling the house apart to adjust the boxes?
Thanks in advance... this is my first post on this site.
Old 11-07-04, 07:59 PM
Received 1 Upvote on 1 Post
Go to your home center and ask in the electrical aisle for box extenders.
Old 11-07-04, 10:15 PM
u2slow
These are the ones we use at work. Might need some longer #6 screws too.
http://www.aifittings.com/m_9.htm
Old 11-09-04, 12:55 PM
scott e.'s Avatar
The box extenders only compensate for the protection of the wires, not the depth of the receptacles. You will also need to place some spacers behind the receptacle tabs to build them out flush with the wall surface. HD or Lowes sells these neat plastic accordian type things that fit on the receptacle mounting screw and hold out the receptacle. Also use the box extenders to protect the connections and wires since they will be partially outside the box.
