220 Volts -- 3 prong to 4 prong
Old 11-09-04, 07:57 PM
seadooridr1
I have recently upgraded my stove. The oven is electric and thus has a 220V 4 prong plug. I relocated the new stove and got rid of the old 3 prong plug. The problem lies in that the old fuse box does not have a neutral bar thus the additional wire is useless. What problem could this cause? The new wire used is 40amp. The older wire is much larger in size.
Thanks
Nick
Old 11-09-04, 08:20 PM
It's probably way too late now, but the original 3 prong circuit would have been allowed to service your new stove. It sounds like you installed new cable and a new receptacle. In doing so, it must be properly connected. This means: black wire-hot, red wire-hot, white wire-neutral, bare-ground.
If you have the stoves instruction manual, follow it exactly. It will tell what size breaker(fuses) should be and what guage wire to use for circuit.
Old 11-10-04, 04:33 AM
Nick,
As Bob100 stated, you should have left the old wiring intact and used it. it is permissible to use existing 3 wire stove and dryer wiring with brand new appliances (as long as the wire and breaker are the correct size).
However, you have elected to replace the wiring. This means that you MUST run four conductor wire and use a four wire receptacle.
make certain that the wire and the breaker are the correct size. The owners manual for the range will tell you what size is needed.
You do have a place at your panel to hook up a neutral, you just haven't identified it yet. Do you have fuses? Do you have a circuit breaker panel? The neutral and the ground may very well hook up to the same place.
Old 11-10-04, 06:38 AM
This statement is incorrect. The additional wire is very useful even though the neutral and ground connect to the same bar in the panel. In fact, the additional wire would be useless if they didn't.
Old 11-10-04, 07:48 AM
Where does/did the Neutral of the "old wire (cable)" connect? Your description - no Neutral bar-implies that the "old" cable terminates on a seperate fuse-block inside an enclosure which is seperate from the Service panel.
