Ground Knob and Tube wiring?
Old 11-15-04, 02:36 PM
choo
I just ran across a statement that Knob and Tube wiring "Cannot be grounded". Does this mean just at the main box? Or does it mean that it's also unsafe to ground at the outlet/switch boxes?
Here's the link:
http://www.thisoldhouse.com/toh/know...98-12,00.html#
Old 11-15-04, 04:01 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
For the effort involved in installing a Code compliant grounding method it would be much better to install new wiring.
Old 11-15-04, 06:02 PM
Received 513 Upvotes on 418 Posts
To properly ground a knob a tube you need to run wire al the way back to panel. Might as well pull whole new cable.
