dimming lights plugged into outlets
Old 11-16-04, 08:19 AM
menderle
Hello, I am curious if I can replace a switch with a dimmer switch that controls a few outlets. Plugged into these outlets are Halogen under cabinet lights. I think there are about 8-10 of them. The lights say they are dimmable and since they are made to plug into outlets I don't see why this would be a problem. Any thoughts.
Old 11-16-04, 08:44 AM
It is technically a code violation to dim receptacles. But it will certainly work, and although I almost never advocate code violations, I'd say you have as good a reason as any. This is only justified if these receptacles are dedicated to the lighting and are never used for anything else.
Old 11-18-04, 05:16 AM
TheColt
X-10
don't forget about X-10 products, they can control you whole home without the need to change or violate any electrical codes.
http://www.x10.com/automation/automation_modules.html
