Installing bathroom fan
Old 11-17-04, 09:54 PM
Leona
Help! We have installed a bathroom fan (first time) and now the problem
is to hook up to the (light) switch. What we did was replace the exsiting
single switch with a 2 switch. But - the fan will not work. We did put the
fan wires on the light switch, but when the light was on, no fan. When the
light was off - fan was on (working) The only two wires are a black and white (the light switch) What are we doing wrong? That switch contains
only the one bathroom light. The new switch has (on one side) connecting
posts (joined) the other side has separate posts. Can you help??
Leona
Old 11-18-04, 04:36 AM
B
If you only had two wires in the original switch box, that is a switch loop for the light. There is no neutral wire present to properly connect the new fan.
Post back and tell what are all the wires in the switch box. If it is how you described, you will need to bring power from another source.
Old 11-18-04, 06:40 AM
Received 1 Upvote on 1 Post
This can be done if you can replace the existing black/white/bare cable from the light to the switch box with a black/red/white/bare cable. This isn't too hard if there is an accessible attic above the room.
Another option is to add a new black/white/bare cable from the light to the fan.
A third option is to run a new black/white/bare cable from another power source to either the fan or to the switch box.
Which is easiest for you?
Old 11-20-04, 09:43 PM
Leona
the easiest would be: "How to hook up power (from another source)
to the fan?" We have the "ppwer from another source" so how do you
do it? How do you hook the "hot" to the fan? - then the "hot" to the switch
(the turns the fan on/off)? How do conplet the circut?
Old 11-20-04, 11:36 PM
R
Do you want to replace the wire going to the switch with a three conductor wire, or do you want to add a new two conductor wire going to the switch?
Old 11-21-04, 08:31 AM
Run a black/white cable from some other unswitched power source to the fan. At the fan:
  • Connect the power cable black wire to the switch cable white wire.
  • Connect the power cable white wire to the fan's neutral.
  • Connect the switch cable black wire to the fan's hot.
At the switch:
  • Break out the tab connecting the two brass screws (bend it back and forth until it breaks off).
  • Connect the black and white from one cable to the two screws on the top.
  • Connect the black and white from the other cable to the two screws on the bottom.
Of course connect all grounding wires and screws in each box.
Old 11-29-04, 10:15 PM
Leona
Smile
Thankyou John! this was exactly what my husband needed to see.
the fan is connected and working wonderfull. Many thanks to the replies.
I'm keeping this web site marked, it is excellent. Glad I picked this one
when I was searching.
