Outlet location question
Old 11-18-04, 08:35 AM
thirdeep
I have hot water baseboard style heaters, I know you cannot have outlets above electric baseboard heaters, does this rule apply to hot water baseboard also? I have a few rooms that the baseboard heater runs the entire length of the wall, {at least 12 feet}. and would like to install a few outlets in those rooms. thanks for any ideas
Old 11-18-04, 12:08 PM
Received 513 Upvotes on 418 Posts
Not a problem. Hydronic heat doesn't get as hot a electric. Electric gets hot enough to melt the cords of anything plugged into the receptacle that might droop down into the heater.
