elec plumbing code question
Old 11-18-04, 07:51 AM
thirdeep
I need to upgrade from old rayon style wiring, I am about to run a 12/2 romex to my attic from my panel in the basement and the easiest way is to follow the sewer pipe up to the second floor, the sewer pipe runs through a 16in.x6in. wall its entire length. and will code allow me to run my romex cable under the bathtub between the floors? thanks for all your input.
Old 11-18-04, 11:07 AM
Received 477 Upvotes on 393 Posts
If by under the bathtub you mean under the floor under the bathtub, that should be OK. If you mean on the floor under the bathtub, I don't think that will pass.
