3-way switch w/dimmer
Yes, it's possible, but you won't like the result.
Leaving one switch alone and put a dimmer at the other switch is the most common solution. If you really need the ability to adjust the dimming from both locations, you'll need a smart switch kit which will set you back at least thirty bucks.
