THHN or USE or What??
Old 11-19-04, 08:00 PM
SkyKing
I am going to run a dedicated circuit to a hot tub (60 amp) load center/GFCI disconnect.
Questions:
Can I use cable type THHN or do I have to use something like USE? Would this be classified as a service wire when carrying power to the disconnect? Can I run more than just the spa off of the feeders to the spa disconnect?
Thanks,
SK
Old 11-19-04, 08:51 PM
pcboss's Avatar
Received 192 Upvotes on 168 Posts
Will this be inside or outside? In a single family dwelling?
More info is needed.
Old 11-19-04, 09:37 PM
SkyKing
Sorry, you are correct!
Indoors in schedule 80, through the garage, basement and then outside (straight into back of panel through knockout).
Single family dwelling (although I'm not sure why this is needed?)
