which way to run pvc conduit
Old 11-20-04, 12:33 PM
Which way do you install PVC conduit? Does the belled end go towards the breaker box or away from it? We just built some shelves in the garage. Later down the road we are going to put in an outlet or 2. I was going to pre-install a pvc corner piece to avoid having to dismantle the shelves when we extend the service for the outlets but I don't know which way to put the corner piece.
Old 11-21-04, 05:05 PM
Makes absolutely no difference. If it is pointed in the wrong direction, you can get couplings to add pieces together. Most likely however, when you finally go to a box, the connector will be threaded on the box end and will be a female on the other end. The bell end direction will most likely be decided on what you use to connect it into your box.
Best of Luck,
Paul
