4 to 3 prong dryer
Old 11-22-04, 10:08 AM
Blueline
4 to 3 prong dryer
Just bought my first home and figured I should sign up to get some good tips from the experts.
The house although built in the 60s has been completely updated and has the new 220v 4 prong for the washer and dryer hookup. I have a 3 prong dryer and would like to use it. I have seen 1 or 2 posts about changing this but by no means am I electric savy. If someone in plan english could help me run through how to hook up the new recepticle I would appreciate it.
Thanks all
Old 11-22-04, 11:14 AM
Received 518 Upvotes on 423 Posts
With the dryer unplugged, take the back off and you will be able to remove the cord. Get a new 4 prong cord and look at the back you removed. Somewhere on it there is likley a drawing of how to hook up the 4 prong cord. If it is not there try going the manufacturer's site and search by model number for the info.
The diffference between a 3 and 4 prong cord is the ground and neutral.
In a 3 prong cord there is only one wire and they are both joined inside the machine. With a 4 prong cord there is 2 separate wires and they have 2 separate connection inside the dryer. There might be a jumper or bonding screw that needs to be removed.
The basic connection are normally lableled as X and Y for the black and red. Doesn't matter which is which.
N for the neutral or white wire.
G for green or bare ground wire.
Old 11-22-04, 06:58 PM
R
Received 2 Upvotes on 2 Posts
Along with Joed's reply view this for clarification if needed.
http://www.american-appliance.com/se...dryer_cord.htm
Old 11-23-04, 04:20 AM
Just in case it isn't clear from the previous replies: your only choice is to change the cord on the dryer to a 4-prong cord. It is a code violation to change the 4-prong receptacle to a 3-prong receptacle. Plus it is a lot easier to change the cord.
