Outlets Not Working
Old 11-22-04, 12:25 PM
livick
Outlets Not Working
I have three outlets (one outside and two inside) that are not recieving any current. All are along the same wall. No circuit braker is tripped. How do I check and fix?
Old 11-22-04, 12:54 PM
Andrew's Avatar
Received 14 Upvotes on 10 Posts
Have you checked for a tripped GFI on one of the outlets?
That's my buest guess.
Good Luck!
Old 11-22-04, 02:51 PM
R
Because one of the receptacles is outside, a tripped GFCI is the most likely culprit.
