Vacuum Shock
Old 11-26-04, 05:13 PM
Question Vacuum Shock
We have a central vac that is switched on and off at the tool end of the hose. I believe the switch system is run on low voltage DC or AC. Whenever I vacuum my shop and touch a piece of equipment that is plugged in and a metal part of the vacuum hose at the same time, I get an electrical shock. I have discovered that the shock is momentary only. I assume this must be static electricity and harmless. Am I right?
Old 11-26-04, 06:20 PM
HandyRon's Avatar
Does it get worse during the wintertime? Then probably static.
Old 11-27-04, 04:14 PM
Does the sawdust stick to the outside of the pipe? Probably static. Potential fire/explosion hazard. Fine dust can explode.
Check out this article.
http://www.cepmagazine.org/pdf/100344.pdf
