Sub Panel Again
Old 11-27-04, 07:39 PM
Sub Panel Again
Can I use just a standard 200 amp panel for a sub panel and can I surface mount a panel be it main or sub??
Thanks
John
Bet you guys will be glad when I get this done!!
Old 11-27-04, 11:19 PM
Received 1 Upvote on 1 Post
Yes and yes, assuming you wire that panel as a subpanel and not as a main panel (e.g., throw away the bonding screw and isolate your neutrals and grounding wires).
Old 11-28-04, 11:12 AM
Then why wouldn't one buy the 200 amp vs 100 amp for a few bucks more??
Old 11-28-04, 11:22 AM
Spending a few buck for something you can use is wise. Spending a few buck for something that you don't need merely wastes a few bucks. Knowing nothing about your needs, I can't comment further.
Old 11-28-04, 03:48 PM
Thanks John N.
