How to ID neutral
Old 11-30-04, 09:21 PM
papi's Avatar
Thumbs down How to ID neutral
HI friends, I been using a non- contact voltage probe to trace some K&T wiring [ two hot and two neutrals running parallel to eachother from the panel trough heating ducts,cold air return and wall cavities] my question is how can i identify the neutral and hot that form a circuit?
Thanks a lot
Old 12-01-04, 06:02 AM
scott e.'s Avatar
unplug everything connected to the circuit and turn off all loads. The wires with no voltage will be the neutrals. Otherwise, K&T makes no differentiation between the hot and neutral.
Old 12-01-04, 06:26 AM
I think papi was asking how to tell which neutral goes with which hot. That's important to know so that you don't overload the neutral.
If you disconnect the neutrals at the panel, you can test it with an ohmmeter and a long wire. Or disconnect just one of the neutrals at the panel and its associated hot and see which hot/neutral pair still has power at the outlet.
But if you're working on K&T, I suggest you spend your time replacing it.
Old 12-01-04, 06:29 AM
scott e.'s Avatar
Thanks for the clarification, John. I didn't read enough into the question.
Old 12-01-04, 07:36 PM
papi's Avatar
Thanks so much for replies,these are the last two K&T circuits left to change,Regards
Old 12-02-04, 06:02 PM
ka3vvv
Thumbs up replace it
That what I would do replace it. I did in my house I just replace it fish the walls down to the basement over to the box.
