Lamp Adapter
Old 12-03-04, 05:14 AM
thiggy's Avatar
Lamp Adapter
I have a few old floor lamps which use three-way mogul base bulbs. As these bulbs are becoming less commonly available and are rather expensive, I was wondering if there is made an adapter which allows the use of a standard three-way Edison base bulb? I have a couple of screw-in adapters but they are not for three-way bulbs.
Old 12-03-04, 08:24 AM
SkyKing
You can replace the wiring socket with a three way switched socket.. they should carry those at any home improvement store.
If you want a quick "how" guide here's a link for you:
http://science.howstuffworks.com/question24.htm
Old 12-03-04, 08:42 AM
thiggy's Avatar
The problem that I visualize with just replacing the old socket with a new one is that they both use different size threaded pipe. The old one is threaded for 3/8" iron pipe, and the modern socket will be threaded for the smaller lamp threaded tube.
Old 12-03-04, 09:06 AM
SkyKing
You could always try it anyway. It will probably only set you back 3.00 dollars and maybe an hour?
Old 12-03-04, 10:56 AM
hornetd's Avatar
There are thread adaptors in the lamp parts rack at any real hardware store.
Tom H
