no power to outlet
Old 12-05-04, 02:08 PM
P
no power to outlet
I have 1 outlet that does not work. All the other outlets in the circuit are working. I pulled it out, checked the connections and they were fine, but when i used my volt meter i am getting no power from the black wire. I checked it using a known ground source. I can't figure out the problem. It is not connected to any GFCI's (and either way all GFCI's are working). Does anyone have any idea what could be happening? Thanks
Old 12-05-04, 02:10 PM
P
could it be
at another outlet where it gets it's feed from?
Old 12-05-04, 02:59 PM
U
Has the outlet worked in the past, any remodeling recently?
Check the other outlets on the circuit for a broken splice or a bad back stab.
Old 12-05-04, 03:40 PM
Received 501 Upvotes on 411 Posts
Problem could be at the box feeding this one. It may not actually be a receptacle. It could be fed from a light or a switch as well.
