Little help please
Old 12-06-04, 07:30 PM
KCPainter
Little help please
I have a double light switch by my front door, one of them is to the front porch light which works fine. The other is the problem, it is a switch that, at one time, controlled a single outlet. The outlet no longer will turn on floresecent light that i have plugged into it. I checked the breakerbox and all of them are still on. Any help would be greatly appreciated.
Thanx
Old 12-07-04, 12:25 AM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Check around for a GFCI receptacle (inside and outside) that may be on that same circuit as the switched receptacle, and re-set it.
Mike
Old 12-07-04, 06:44 AM
sjr
You could try to plug another device into that receptacle and see if it works.
Could also be that the receptacle has back-stabbed connections which have become loose.
Old 12-07-04, 05:52 PM
R
Buy or borrow a receptacle tester and tell us what it indicates when you plug it in.
