120v Forced Air Heater vs. 240 Baseboard
Old 12-08-04, 09:16 AM
AndyH
Hi,
I am adding a heater and thus have to give a dedicated circuit. If I have to add the circuit, should I add a 240 volt and add baseboard vs. a 120 volt forced air? Is baseboard better/ more efficient?
Thanks, Andy
Old 12-08-04, 09:20 AM
Received 1 Upvote on 1 Post
A 240-volt system provides more power for the same size wire, but it also takes up more space in the panel. The decision is yours to make, but it depends on how much heat you need and which unit you like better. They are equally efficient.
Old 12-08-04, 09:26 AM
dougm's Avatar
Baseboard heat is usually more comfortable and quieter.
Doug M.
Old 12-08-04, 05:08 PM
Andrew's Avatar
Received 14 Upvotes on 10 Posts
Choosing between baseboard and fan-forced would be dictated by the application. Tell us exactly where the unit is going to be used, and we can help further.
Andy
