Blue Xmas..GFCI outlet keeps tripping off
Hi,
New to the website! Question: I hung up the exterior xmas lights and plugged them into the GFCI. it stayed on for 5 minutes then poof...gone..I could reset but again it only works for 5 mins or less!! Any ideas?Cheers from Canada
I should have mentioned the ammount of lights!! NO.its not a Clarke Griswold!! only 3 strings..and it is a GFCI outlet..standard outside wall one..
Question: if the electrical cord in the string of lights is damaged..i.e. by an errant staple..could this cause it to fault after a few minutes??
p.s. thanks for ur replies. Update.. I plugged in a smaller set of lights and also a small jig..the saw worked fine then after I stopped about 1 minute it tripped again..hmmm
So is it the GFCI receptacle into which the bulbs are plugged that trips? If so, then yes, a staple could cause this. So could moisture. Is there snow or rain or high humidity where you live? Are the lights rated as exterior?
Originally Posted by racraft
try plugging something else in and see if it stays on. If it does stay on then replace the lights.
prhaps i should replace the entire outlet?
