neutral leg problem
Old 12-09-04, 06:25 PM
transwizard
neutral leg problem
confused: anybody have any good ideas on tracing a lost neutral leg
in an old house
Old 12-09-04, 06:31 PM
In an hour or less, you can look in every box on the circuit. This brute force way is as good and fast as any high-tech way. It's not rocket science. Just start with one box and go on to the next one.
Old 12-10-04, 03:09 AM
Would this be the same as finding an "open ground"??
Old 12-10-04, 07:40 AM
Open neutrals are usually caused by failed backstab connections. Since grounding wire are never backstabbed, the open neutral can be a bit harder to find (unless you're using conduit for grounding).
