FPE Stab-Lok
Old 12-14-04, 11:49 AM
bulldog88
FPE Stab-Lok
150Amp box - i've been told to replace this due to dangers and see if upgrade to 200Amp is allowable. Your thoughts on this are much appreciated.
Old 12-14-04, 01:21 PM
Very Good Idea
Change out the FPE panel as soon as possible. I've seen pictures of FPE circuit breakers that don't trip causing a fire in the FPE panel.
FPE Panels/circuit breakers are JUNK and very dangerous!!
Old 12-14-04, 05:56 PM
I agree that you should replace this panel with a safe one. However, whether to upgrade to 200 amps or not is another question. Of course if the upgrade will do you any good, doing it when replacing the panel is certainly the right time to do it. The question is whether or not 200 amps do you any good. If you have a house under 2000 square feet and all your major appliances (cooking, clothes drying, home heat and hot water) are gas, you have no use for 200 amps. Otherwise, consider it.
Old 12-14-04, 07:04 PM
Fpe?
Mind if I ask what FPE stands for?
Does it have anything to do with Federal Pacific? My dad's old house has a 200 AMP Federal Pacific breaker box, and he's mentioned that he doesn't trust it because of what others have told him...He plans to replace it with a Square D box.
Thanks
Old 12-14-04, 07:21 PM
Yes, it's Federal Pacific. It's only the old ones in the U.S. that are a problem. The new ones in Canada (sold as Federal Pioneer, I think) are supposed to be okay. I don't think FPE does business in the U.S. any longer. They blackened the name too much to ever use it again.
For the record, FPE has always denied that it has any problem. But a number of government agencies have strongly disagreed.
Old 12-14-04, 07:39 PM
He's told me that he has heard stories of problems like you mentioned.
His house was built in 1978, and I don't know that he's ever had a problem with any of the breakers. Would you advise replacement anyway?
FWIW: He is currently building a new house (and will be selling this one) and he wound up with an extra Square D homeline box with a 200AMP main, so he'd just need to buy breakers. The panel is easily accessable, and the wires should be long enough to reach (if not the box can easily move up a bit). Still, that's quite a job (he'd have a relative who is an electrician do it).
Old 12-14-04, 07:42 PM
If your family car had no seat belts, would you be looking to upgrade? The answer to this question is the same as the answer to the question of whether to upgrade the panel.
