Romex in unfinished garage ceiling
Old 12-14-04, 03:48 PM
Kray
Is it OK to run romex cable through the joists of an unfinished garage ceiling, or is "protection" required in this situation?
Thanks.
Old 12-14-04, 04:56 PM
R
Most people would consider this okay.
Old 12-14-04, 04:58 PM
Received 513 Upvotes on 418 Posts
I believe across the joists protection is required. You don't want people using the wire as a clothes line. Same applies to unfinshed basement.
Old 12-14-04, 05:04 PM
R
Yes, across would require something, but along the joists would not need protection. I was not thinking of across when I answered.
Old 12-14-04, 06:11 PM
Received 1 Upvote on 1 Post
Through bored holes in the joists is perfectly acceptable. It's up to you not to use them as a clothesline.
Old 12-16-04, 07:41 PM
B
Received 13 Upvotes on 9 Posts
Old 12-17-04, 07:25 AM
pgtek's Avatar
hi
there a no no to drill thru truss.
I would used pvc pipe to run them thru ot just staple the wires to be near the side of truss.
Some people used these as hoist thats a no no
cheers
pg
Old 12-17-04, 08:01 AM
The original poster used the word "joist". But, as guessed by you guys, he may have misspoke and meant "truss" instead. If so, you guys are right and he should not drill.
