What Kind Of Wire?
Old 12-16-04, 01:40 PM
papi's Avatar
What Kind Of Wire?
Hi friends is there some kind of wire that can be run surface outside of conduit besides metal armor? Anyone knows what formed wire is? Thanks so much
Old 12-16-04, 06:32 PM
Google "wiremold"...it is similar to what I think you're talking about.
Old 12-17-04, 07:27 AM
pgtek's Avatar
Received 1 Upvote on 1 Post
there the aluminium sheated cable you can used or there the bxl
cheers
pg
Old 12-17-04, 11:46 AM
papi's Avatar
Thank you for replies.Wiremold seems to be a good product but im not sure how the pre-wired sections work
Pgtek is the aluminum sheated metal clad cable type mc?
WHAT IS BXL? THANKS AGAIN
Old 12-17-04, 04:12 PM
BX is the armored cable you said you didn't want to use. The prewired sections of wiremold attach to the receptacles (or rather the rec's attach to it), wherever you want them, and the rest is covered by plastic snap on covering, cut to fit(by you).
Old 12-17-04, 11:48 PM
papi's Avatar
Thanks a lot///
Old 12-18-04, 08:43 AM
Received 513 Upvotes on 418 Posts
You can run NM-B on the surface if it is not subject to damage.
