What Kind Of Wire?
What Kind Of Wire?
Hi friends is there some kind of wire that can be run surface outside of conduit besides metal armor? Anyone knows what formed wire is? Thanks so much
Thank you for replies.Wiremold seems to be a good product but im not sure how the pre-wired sections work
Pgtek is the aluminum sheated metal clad cable type mc?
WHAT IS BXL? THANKS AGAIN
BX is the armored cable you said you didn't want to use. The prewired sections of wiremold attach to the receptacles (or rather the rec's attach to it), wherever you want them, and the rest is covered by plastic snap on covering, cut to fit(by you).
