Cutting power
Old 12-19-04, 10:38 PM
papi's Avatar
Cutting power
Hi all
I need to cut the power permanentely to a branch of K & T .
Is it enough to disconect this particular circuit fuse or do i need to open the fuse panel disconect and remove the hot and neutral wires?Thanks a lot
Old 12-20-04, 12:14 AM
I would remove the wires myself, someone...someday could simply put the fuse back in and burn your house down...in theory anyway.
Old 12-20-04, 04:41 AM
R
Post
If you are permanently removing this circuit then you need to remove the wires from the fuses. You don;t have to remove the wires from the walls if you don't want to. but I would certainly remove everything easily accessible in the basement.
