Seperate 220v lines for Cooktop & Wall Oven?
Old 12-24-04, 08:22 AM
brianosaur
Smile Seperate 220v lines for Cooktop & Wall Oven?
Currently I have a 220v kitchen range on a 40a breaker.
During my upcoming remodel I would like a seperate cooktop and wall oven.
Do each of these appliances need a dedicated 220v line?
It would appear that the amount of electricity used would be the same, just running to two units instead of one.
But I have a nagging feeling they should be on seperate lines.
Old 12-24-04, 08:29 AM
Received 1 Upvote on 1 Post
They can be on the same circuit, and commonly are. But there are a lot of complicated rules about what size breaker and what size wire to use, and it depends on the exact KW requirements of both appliances. I suggest you have an electrician size it correctly for you.
However, since it is unlikely that a 40-amp circuit will support both, you'll have to run new cable anyway. And since you have to run new cable, separate circuits are preferred anyway.
