No Main
No Main
A relative of mine was showing me his service box in his home..... I noticed to my surprise their are no main circuit breakers........
I do not believe this is code what-so-ever....... The home was purchased this way.. I advised him to check into correcting this........ He said he was told it was not neccessary................. ? Thanks
Split-bus panels have no main breaker. And some panels have an external main disconnect. Split-bus panels were legal in their day (the six top half breakers collectively act as the main disconnect), and of course an external disconnect is still legal.
I have seen numerous panels with the main, an average looking 2-pole CB, in the middle of the lineup. It is usually, but not necessarily, a 60 amp. Could be 100, though. As John Nelson said, this is often a "split bus" panel. As is too often the case, there is no panelboard legend identifying the breakers, so to the casual observer ,who is looking for the main to be a larger than normal breaker up top and centered, it would appear as though there was none. If you don't mind re-setting the time on your VCR, digital clocks, etc., I would suggest killing your 2-pole breakers one at a time until you see the whole house go down with one of them. And then label that breaker with the word "main".
Or it's possible that you have a main disconnect outdoors. But I have never seen a home with no main disconnecting means, so that is not likely to be the case.
Juice
Juice
