Reload this Page >
Replacing Honeywell Heat Pump Thrmostat with Hunter 44760 Auto-Thermostat.
Old 12-27-04, 05:24 AM
Trek5900cyclist
Please help!
I tried to replace my Honeywell thermostat with the Hunter 44760 Auto Thermostat. But after I installed the new Thermostat, the main menu on the digital read out keeps telling me that there is "No AC power".
I own a Condo here in Chesapeake, VA and don't know the model or year of the old Honeywell system. I suspect there is a wiring problem.
Can someone tell me where the following 7 wires should be connected? Also, do I need to use a jumper wire?
O,R,W2(light blue),Y1,E(light brown),White, and G.
Please respond to my email address at home:LindaWillard@webtv.net
Thank you.
Kelly W. Skillett
Chesapeake,VA
Work: (757)445-6129
Cell phone: (757)619-8414
Old 12-27-04, 07:31 AM
T
You should post in the heating forum...this is not really an electrical issue.
Also, all responses will be posted here on this forum..
Also, I'm not sure it's the best idea to post all your phone numbers... many people can see them..
