meter base
Old 12-27-04, 05:32 PM
iceburg
meter base
If my meter base is rated @ 100 amps and I want to upgrade to 200 amps in order to change my 100 amp service to 200 amp, will the power company have to change their meter?
Old 12-27-04, 05:42 PM
Speedy Petey's Avatar
The meter itself is the responsibility of the POCO. If it needs to be changed they will change it. If it is a standard plug in style meter it is normally not replaced.
In some area the POCO is also responsible for the meter base, but this is not the norm. Typically a service replacement is everything from the weatherhead down to the panel and grounding/bonding, and everything in between. This is all the responsibility of the customer.
Old 12-27-04, 05:43 PM
Received 1 Upvote on 1 Post
Maybe, but only they can answer that. There may be other things that need replacing too.
