Wiremold
Old 12-29-04, 11:02 PM
papi's Avatar
Wiremold
Can wiremold be use to extend a circuit from one room to another without ''fishing'' wires through the walls?
Thanks a lot
Old 12-30-04, 01:28 AM
HandyRon's Avatar
Absolutely.
Old 12-30-04, 05:28 AM
Yes, you can use wire mold to extend a circuit. However, the circuit must be extend-able. This means the circuit must be three wire. You cannot extend a two wire circuit.
Old 12-30-04, 10:22 AM
papi's Avatar
Thanks very much for replies ,maybe i should rephrase my question
How do i run the wiremold from a hallway to an adjacent room where a door is the only openning between the two rooms?
How can i run the wiremold through the door jam?
Thanks so much
Old 12-30-04, 01:05 PM
In order to use wiremold through a doorway, you would have to cut out a piece of the door jamb.
If this is an adjacent room, why not just put the new receptacle in the same stud cavity, completely avoiding the need for wiremold.
Old 12-30-04, 10:12 PM
papi's Avatar
Im trying not to make holes on the plaster walls untill summer[ comlete rewiring],also there is no common wall ,the room door is at the end of the narrow hallway.Thanks again
Regards
