Still no lights
Old 12-30-04, 03:10 PM
Ally
Still no lights
Does it matter what order you put the black and white wires in a new outlet as long as the the ones coming from the same conduit are oppisite eachother???
Thank You
Old 12-30-04, 03:20 PM
Received 1 Upvote on 1 Post
It does not matter from an operational point of view (i.e., it will still work if you reverse the wires), but it definitely does matter from a safety point of view. This is one of the reasons I repeat this mantra often: "Not everything that works is safe."
Old 12-30-04, 04:46 PM
Andrew's Avatar
Received 14 Upvotes on 10 Posts
Normally, the black (hot) is attached to the brass screw, and the white (neutral) is attached to the silver screw.
