outlet types
outlet types
I've read enough of the previous posts to know the consenus on backstab connections. I would like to know what the feeling is for outlets where you insert the wire from behind and then the screw tightens a clamp which holds the inserted wires. These outlets preclude you from wrapping the wire around the screw and do not provide the typical backstab connections.
The ones I've seen are referred to as "specification grade", or spec-grade. Those are proper wire clamps and make excellent terminations in my opinion. Almost as easy as back-stabs but without the future headaches. I say go for it. Expect them to be more expensive than regular grade receptacles, but the quality of those I've seen by Pass & Seymor, Leviton and Hubbel/Bryant is excellent.
Juice
Juice
