All wall plugs connected in one box
Old 01-18-05, 04:08 PM
Have an older home have noted that in one side of house all the wall plugs wires come up through walls and connect in a single box. With one lead going to breaker box. Lead to box is 12ga but to plugs is 14ga. Plugs are in 2large bedrooms a total of 10 plugs. 20 amp breaker. This is not good in my mind. Have room to add lead and split circuit Any thoughts would be appreciated thanks
Old 01-18-05, 04:22 PM
Yep. I'd do it.
Old 01-18-05, 04:49 PM
Thanks will do Would this be a common thing ? Walls are 1x6 and 8's then wall covering then sheetrockon top. 5 plugs and one lead to box ok? Wireing in wall loose and not anchored. Go to 12ga to plugs needed?
Old 01-18-05, 04:52 PM
You didn't say how old this "older" house is, but this wiring style probably hasn't been common for the last 60 years or so.
Old 01-18-05, 06:28 PM
As a minimum you need to install a 15 amp breaker. This will correct the immediate issue of a 20 amp breaker incorrectly being used on 14 gauge wire.
As to correcting the problem of 10 receptacles on a single 15 amp circuit, that is not a problem, unless the breaker is constantly tripping, or you are having to worry about what loads are turned on at the same time.
As far as adding a new circuit, you may find it easier to leave what is in place (correcting the breaker), and simply add a new circuit or two.
Old 01-18-05, 08:16 PM
Thanks for the info. as conversation. Orig. home built in 1926 added on and remodeled 1949-51. the older part still has 2 single wires with glass insulators and no boxes on lighting fixtures and splices are only wraped with friction tape. looks like a cloth tape. Have not had breaker problems but have been very careful as to what gets plugged in. Changed service panel 2yr ago and have dedicated ckt`s for high load appilances. Working on this as time and money permits. Have lived here for 22yrs Thanks again WP
