Ground conection
Old 01-18-05, 10:52 PM
papi's Avatar
Ground conection
Im splicing four 14/2 in a 4x4 box, Im wondering what is the correct way to conect the grounds can i use one of conductors ground wire to loop around the box ground screw and continue as a pigtail to conect with the other three ground wires?
Should i just conect a pigtail and the four ground wires together?
or should i use one of the special ground conectors[ with a hole on the top to let one of the grounds through it]
Thanks for help
Old 01-19-05, 12:45 AM
K
I use your first method, always cutting the cable feeding the box a bit long and having it enter the box near a ground screw. I figure there's less clutter this way.
Also curious to know if this is acceptable.
The only problem I imagine is that in the case of that cable being violently pulled a few inches out of the box the ground would break instead of stretch. On the other hand it's harder to pull out with the ground looped around a screw.
