How do you deactivate a wall light?
Old 01-19-05, 05:45 PM
besullivan
Question How do you deactivate a wall light?
I want to deactivate a wall light and patch the hole and paint over. What do I need to do wiring wise?
Old 01-19-05, 06:19 PM
How many cables come intothe box?
You need to find the other end of all the cables and disconnect the wires from there. Once all the wires are disconnected and cut off so they can't be reconnceted then you can remove the box and patch the hole. The old wires since they are dead can be left in the walls.
Old 01-19-05, 06:22 PM
ampz's Avatar
Is it controlled by a switch? If so the wire will have to be removed from the switch,{cut out of the box} so it cannot be reconnected by others.The feed into the switch is probably coming from another box. In which case it is best to cap off the wires & use a blank plate.That wire must still remain accessible.
Old 01-19-05, 06:46 PM
besullivan
deactivate light
1 swithch controlling two separate lights over fireplace, new house, just useless lights
Old 01-19-05, 06:48 PM
besullivan
wires coming out of each box
three wires come out of each
Old 01-19-05, 08:08 PM
This is ambiguous. Can you clarify?
