How to secure wire on finished wall wiring
Old 01-24-05, 07:28 PM
Bill2003
Obviously when you run new wire in an unfinished room, you attach the wire with wire staples which secure the wire and keep it from flopping around. I know the wire has to be attached within a certain number of inches to boxes or lights.
What is the equivalent when new wire is run in a finished room? I am adding a new outlet to a bathroom, I am running the wire down from the attic through the wall to the outlet. Am I supposed to secure the wire somehow? I am using a plastic retrofit box so there is really no way to clamp the wire to the box, it just runs in the little opening which secures it a little but not much. Just wondering if there is any rule on connecting the wire in this situation.
Old 01-24-05, 07:39 PM
turboboy
for remodeling work as you describe nec does not require the wire to be secured other than at the box. i assume the plastic box has the built in clamp inside it to secure the cable. :mask:
Old 01-24-05, 07:40 PM
Code does not require any stapling for cables fished into finished walls.
Old 01-24-05, 07:42 PM
Bill2003
Thanks
Thanks for your reply.
Yes, the plastic box has that built in opening for the wire that sort of acts as a clamp. I guess that is sufficient.
