electrical tester question
Old 01-31-05, 09:23 AM
thirdeep
I have a greenlee cmt 60 cat lll clamp type electrical tester. my question is how do I measure amperes with it I turned the dial to the proper setting clamped the clamp around a hot ac wire and got no reading. do I need to also do something with the test leads at the same time I have it clamped around the hot wire? I havent tried that for fear of ruining the tester. thanks for any answeres.
Old 01-31-05, 09:44 AM
You can only clamp it around a single conductor. Clamping it around a Romex cable, for instance, will give you no reading. Test leads are not required for the AC amp test.
Juice
Old 01-31-05, 12:56 PM
Your appliances draw the current when running.
If you don't have something plugged in and turned on the reading will be zero.
