Cold water pipe grounded to hot?
Old 02-04-05, 10:05 AM
Tim_Paget
The house I'm remodeling has a jumper from the cold water pipe to the hot water pipe immediately above the water heater. Anyone know if this is okay? Should I remove it or just leave it? Thanks in advance!
Old 02-04-05, 10:28 AM
scott e.'s Avatar
it is ok, the jumper is bonding the hot water side to the cold water side in case the water heater is ever disconnected from the lines.
Old 02-04-05, 11:44 AM
Leave it. It's required so that the hot water pipes are also grounded.
